zsala001
#1 Posted : Monday, September 29, 2008 8:38:21 AM(UTC)
zsala001
how do I remove the pump from this washer since it is beltless and attached to the motor?
stumblinbumblin
#2 Posted : Thursday, October 9, 2008 11:40:56 AM(UTC)
stumblinbumblin
Just remove the two metal clips holding the pump onto the motor.
v2k04
#3 Posted : Thursday, October 9, 2008 12:53:40 PM(UTC)
v2k04
the easiest way is to remove the screws from the control panel flip the control panel up on it's hinges then remove casing, front,sides,top all come off as an assembly from there you can see the pump attached as mentioned by two clips remove the clips and hoses and remove pump
