3 Pages123>
lmmtz1
#1 Posted : Thursday, October 9, 2008 9:40:40 AM(UTC)
lmmtz1
Quit making ice. I am thinking it is the relay that open the valve but I am not sure where it is? No water is going to the maker. Thanks
v2k04
#2 Posted : Thursday, October 9, 2008 9:41:55 AM(UTC)
v2k04
check to make sure the fill tube isn't frozen over amana is famous for that if it is frozen replace the fill valve
lmmtz1
#3 Posted : Thursday, October 9, 2008 9:46:14 AM(UTC)
lmmtz1
it was frozen and I thawed it out where is the fill valve?
v2k04
#4 Posted : Thursday, October 9, 2008 9:48:35 AM(UTC)
v2k04
it's in the back where the water line hooks up what happens is the valve doen't close shut all the way after a fill and water dribbles down the fill tube and freezes and keeps building up until its frozen also a reverse osmosis system plumbed into water supply will cause the same issue cause of low pressure
lmmtz1
#5 Posted : Thursday, October 9, 2008 9:51:15 AM(UTC)
lmmtz1
It hasnt frozen since I thawed it out so it doesn't seem like the valve is slightly open? thanks also is it the primary or secondary valve?
v2k04
#6 Posted : Thursday, October 9, 2008 9:53:19 AM(UTC)
v2k04
ya they will sometimes just freeze out of the blue for no apparent reason, If its a dual valve one is for wter disp. other for icemaker it comes as an assembly or hard water deposits build up in tube making water droplets stick to it
lmmtz1
#7 Posted : Thursday, October 9, 2008 9:57:26 AM(UTC)
lmmtz1
so you think that it is the valve?
v2k04
#8 Posted : Thursday, October 9, 2008 10:03:09 AM(UTC)
v2k04
I would wait untill it does it again if it does then I would look at replacing valve
lmmtz1
#9 Posted : Thursday, October 9, 2008 10:04:25 AM(UTC)
lmmtz1
it has been over a week when it stopped working
v2k04
#10 Posted : Thursday, October 9, 2008 10:16:29 AM(UTC)
v2k04
usuallywhat I do when I go to someones home to repair an icemaker and find the tube is frozen I will thaw it out and have them watch it, if it happens again and I get a callback in a week or month or so I will go ahead and replace the valve and check the fill tube for hard water deposits andf replace that too if it needs it
Guest (10)
3 Pages123>
