2 Pages<12
Applianceaid
#11 Posted : Tuesday, March 8, 2011 9:24:35 PM(UTC)
Applianceaid
If the thermal has been replaced you would want to check the power coming into the back of the dryer. You will need a volt meter to complete this repair.
ApplianceRepairLesson.com
#12 Posted : Wednesday, March 9, 2011 12:53:40 PM(UTC)
Originally Posted by: dryergirl Go to Quoted Post
Model No. for dryer which won't start is 110.82832100 Can you give me any other suggestions for problem areas since I already replaced the thermal fuse?
Perform the troubleshooting test #1 on page 4 as described in the Tech sheet and post the results. The Tech sheet is attached to the reply.
File Attachment(s):
Tech Sheet - 8529960 - HE3 and Duet dryers.pdf (496kb) downloaded 10 time(s).
2 Pages<12
