If the thermal has been replaced you would want to check the power coming into the back of the dryer. You will need a volt meter to complete this repair. ApplianceRepairLesson.com
Originally Posted by: dryergirl  Model No. for dryer which won't start is 110.82832100 Can you give me any other suggestions for problem areas since I already replaced the thermal fuse? Perform the troubleshooting test #1 on page 4 as described in the Tech sheet and post the results. The Tech sheet is attached to the reply. Gene.
