strutta
#1 Posted : Wednesday, October 8, 2008 2:46:26 PM(UTC)
strutta
I have a 3 cycle washing machine that recently kept getting stuck between the rinse and the spin cycles. It gets to the end of rinse cycle and just keeps pouring water threw the barrel, never filling or going into spin cycle. Won't stop unless you stop it manually and put it on spin and turn back on. I already purchased a new timer from your company and installed it. The machine worked for 3 to4 days and now doing the same it was before the new timer. So did I get a defective timer or do I have other problems? If other , what new parts do I need?
Thanks for any advice you can give me, Chad Titus
iamigor5@yahoo.com
#2 Posted : Wednesday, October 8, 2008 4:17:37 PM(UTC)
iamigor5@yahoo.com
chad,try pulling the drain hose out so only about 6 inches of hose is in drain.
Drags1998
#3 Posted : Wednesday, October 8, 2008 4:27:00 PM(UTC)
Drags1998
Rite on!!!!!!!! It sounds like it is syphoning the water out, raise the end of the drain hose higher than the top of the tub and it should straighten out!!:)
strutta
#4 Posted : Thursday, October 9, 2008 5:07:11 PM(UTC)
strutta
Thank you for your advice. After I tried what I was told, I've done 5 loads of laundry. Everything seems to be working properly. Thanks again. Have a good one. Stutta
timer problems (Dryer Repair)
by fordphantom40 6/18/2015 12:53:10 AM(UTC)
Knob Timer Problems (Washer Repair)
by RickTim 2/23/2011 9:44:32 AM(UTC)
Timer problems on Maytag Atlantis washer (Washer Repair)
by Zeffer 1/17/2011 8:57:58 AM(UTC)
timer problems (Washer Repair)
by eliot19 4/9/2010 9:14:45 AM(UTC)
Timer problems (Washer Repair)
by hitmehhh 4/9/2010 4:28:23 AM(UTC)
Dryer Timer Problems (Dryer Repair)
by Paulm77 2/6/2008 1:31:47 PM(UTC)
