Tub Nut and Tub Block warn. How does Pinion Shft get removed form the transmistion?
You dont have to remove it!!! Remove the cabinet, Remove the White plastic sub-top, Remove the agitator, remove the Tub Nut, Remove the wash basket, The block should slide off the basket drive, clean the top of the basket drive. You will notice 2 tabs on the top of the drive, They will fit TIGHTLY into the NEW drive block!!! Aline the new drive block notchs with the tabs on the drive and MAKE SURE the block is ALL THE WAY DOWN onto the drive.(a few TAPS with a hammer and a small block of wood often helps) Reinstall the wash basket and TIGHTEN the NUT TIGHT!!!
