6470zzy
#1 Posted : Sunday, March 6, 2011 12:10:24 PM(UTC)
6470zzy
I noticed today that my oven never heated up to its setting of 350F, I was waiting in the kitchen for the preheat light to turn on and it never did. I opened the oven after about 20 minutes and it was warm but not hot by any means. I turned the oven to broiler and the top element did heat up, so then I turned the oven back off, waited 15 minutes and turned it back to a 350F setting and it did reach temp. So what do I have here an oven t-stat that its on its way out? Thanks for your help.
Joe / APP Team
#2 Posted : Monday, March 7, 2011 11:54:50 AM(UTC)
Joe / APP Team
Ozzy,
You don't have a thermostat, you have an electronic control/ERC.
You should be checking the oven temperature sensor first
Part number: AP2023913
It should read less than 1100 ohms resistance at room temperature.
And 1350 to 1400 ohms at 212 degrees(boiling water).
Did you not have any failure codes, recently ?
Do you have a multi meter to test the circuitry ? it'll come in handy, if you can get your hands on one.
Guest (4)
