marncrump
#1 Posted : Tuesday, October 7, 2008 8:06:02 AM(UTC)
marncrump
I recently replaced both boards and now my LCD lights (using diagnostic) is working. Do I have to do anything to reset the icemaker.... if not, when will the icemaker begin producing ice again?
libertyappl
#2 Posted : Tuesday, October 7, 2008 9:52:38 AM(UTC)
libertyappl
Is the icemaker getting water into it? Please post your model number.
Nat
marncrump
#3 Posted : Tuesday, October 7, 2008 11:14:15 AM(UTC)
marncrump
Thanks, initially a little water did go in - not full all the way.... It is a Kenmore Elite 10652602100. Thanks for any help you can give.
libertyappl
#4 Posted : Tuesday, October 7, 2008 11:41:58 AM(UTC)
libertyappl
lets switch the electrical leads on the water valve, located on the back of the unit. Then push the water dispenser lever and see if you get water into the icemaker.
Nat
marncrump
#5 Posted : Tuesday, October 7, 2008 12:13:17 PM(UTC)
marncrump
if that works, what's the problem? I've never switched the electrical leads -- is this difficult.
libertyappl
#6 Posted : Tuesday, October 7, 2008 12:52:50 PM(UTC)
libertyappl
Switching the leads is easy. If you get water in the icemaker then it's the icemaker motor module it'se (cheaper to get a whole new IM) if you don't then the valve is not working properly.
Nat
marncrump
#7 Posted : Tuesday, October 7, 2008 2:15:15 PM(UTC)
marncrump
I can't find a diagram of the water valve to determine location of leads - I know that's pitiful... can you give me some guidance...
marncrump
#8 Posted : Tuesday, October 7, 2008 2:16:06 PM(UTC)
marncrump
Also, my husband and I are pastors at a church in Atlanta.
libertyappl
#9 Posted : Tuesday, October 7, 2008 2:55:06 PM(UTC)
libertyappl
You can look at the breakdown on searspartsdirect. The valve is on the back rear of the machine, behind the lower panel.
just pull the wires off and switch places with them.
Glad to hear you are in the ministry, Praise God! We do the jail house ministry on our own we're not affiliated with a denominational church.
Natalie
