My whirl pool washer as of the last few days is acting up. WHen I start a load of laundry and come back to it I find it still full of water and not doing anything. SOme time if I play with it it will start other times I have to let it sit for a while and restart the rinse cycle. Please help me:confused: :(
Your lid switch is broken, either replace itor bypass it. Nat
When you say you are playing with it, are you playing with the timer dial to get it to come on? If so it could be the timer. A natural thought by most techs is to think lid switch. If you did do what Nat said, and the condition did not change, then replace the timer. Tom ApplianceEducator.com
