JoanR
#1 Posted : Thursday, January 27, 2011 5:54:10 PM(UTC)
JoanR
While replacing door handle, I accidently broke one of the door latches. I replaced with new door latch and now when door is closed the inside light remains on. I have unplugged multiple times, and that doesn't help. Display panel shows no error. I can still set the clock and turn fan and under light on/off, but cannot coko because I get beep sound.
What could it be? :confused:
Applianceaid
#2 Posted : Thursday, March 3, 2011 7:39:03 PM(UTC)
Applianceaid
Hello,
Sounds like you have an issue with the door switches, they will cause this issue. If you have a volt meter you can test the switches. Microwaves hold a lethal voltage even unplugged. If you don't have high voltage experiences you may want to hire this out to a technician. Below is a link if you feel up to it.
Microwave Video : ApplianceRepairLesson.com
