I found this forum really helpful. So wen I hit a problem I thought I would check with this community as it has been most likely been solved before,
Yes the infamous -F3- problem is back.
My question is: I noticed when looking for replacement keypad's "Key Panel" (item # 10" in GE database for this model), there are three distinct part numbers listed.
PS753840/41/42
In an earlier post I had seen a expert provide a PDF guidance on how to replace the key pad. There, there was a mention of two variants of the Keypad part. However, that was for a different microwave or a different model.
My question is does anyone have any idea how to determine the right part number, before I spend $80 on ordering the wrong one. I am hoping there is a number on the original when I pull it apart(fingers crossed)
Any help would be appreciated.
Originally Posted by: ppgopete ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I found this forum really helpful. So wen I hit a problem I thought I would check with this community as it has been most likely been solved before,
PS753840/41/42
Any help would be appreciated. In most cases, consecutive part numbers designate a color : (example ) ps753840 may be white and the 41 may be a black, etc. Supply us with a complete model number and we'll be happy to advise you of the part needed. :) :) :)
Actual Microwave model is JVM1870SF03 spacemaker under the hood model
The keypad is black background with white text
:) Thanks
Originally Posted by: ppgopete ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Actual Microwave model is JVM1870SF03 spacemaker under the hood model
:) Thanks Apparently we're using different parts screens ? The part number needed per the GE parts diagram and the model number you supplied, You need MPN no. WB07X10629 AppliancePartsPros part no. Part number: AP3418746
Aah! I see why the part numbers are different, you are referring to the entire assembly. I was referring to only the membrane key panel retails aroun $70 while the assembly is closer to $150 Do you have a separate kepad or keypanel membrane available in ApplianceParts? I am talking about item #10 in the attached parts diagram. Thanks for all the help ppgopete attached the following image(s):
Originally Posted by: ppgopete ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Aah! I see why the part numbers are different, you are referring to the entire assembly. I was referring to only the membrane key panel retails aroun $70 while the assembly is closer to $150
Thanks for all the help Sorry, But we don't have a part number for the touchpad panel as an individual part number, in any of our parts resource screens, I have a feeling, if you order the pad assembly alone, it may substitute over to the complete assembly, (the part I listed) ? Good Luck :) :) :)
