Start Button, which is a bit wiggly, will not start dryer. I replaced thermal fuse, still lights come on, including light for lint filter. I pulled out and cleaned lint filter, still not starting.
What is the complete model number of the dryer?
Hello, We would need the complete model number to help you repair your unit. If you have a volt meter we can walk you through your repair. These units have several very common issues, with a volt meter we could narrow it down relatively quickly.:) ApplianceRepairLesson.com
Originally Posted by: Applianceaid Hello, We would need the complete model number to help you repair your unit. If you have a volt meter we can walk you through your repair. These units have several very common issues, with a volt meter we could narrow it down relatively quickly.:) ApplianceRepairLesson.com I do have a volt meter. I have an Admiral ADE7005AYW dryer. I got it for free only to find out it does not run. Can I by pass the missinf door switch to test it?
I think that may be the number of the matching washer. Purchase together.
Originally Posted by: dryergirl I think that may be the number of the matching washer. Purchase together. Yes this is model number of the washer. We need the model number of the dryer. It suppose to be on the door frame. Gene.
Originally Posted by: Dwight B I do have a volt meter. I have an Admiral ADE7005AYW dryer. I got it for free only to find out it does not run. Can I by pass the missinf door switch to test it? You may want to start th troubleshooting by testing for continuity the thermal fuse (#6 on the diagram). - The thermal fuse Part number: AP4048636
Hiya, If you have a volt meter and can read it lets get started, what voltage do we have at the terminal block? Measure from the middle to right, you get____? measure from middle to left, you get___? If the unit wont start we are loosing power somewhere, lets start at the beginning, keep it simple. Attached is a video that explains how to test the dryer cords terminal block. Terminal Block VideoI'Ll wait for you're reply. ApplianceRepairLesson.com
Model No. for dryer which won't start is 110.82832100 Can you give me any other suggestions for problem areas since I already replaced the thermal fuse?
