2 Pages12>
dryergirl
#1 Posted : Wednesday, March 2, 2011 10:28:59 AM(UTC)
dryergirl
Start Button, which is a bit wiggly, will not start dryer. I replaced thermal fuse, still lights come on, including light for lint filter. I pulled out and cleaned lint filter, still not starting.
#2 Posted : Wednesday, March 2, 2011 6:03:48 PM(UTC)
What is the complete model number of the dryer?
Applianceaid
#3 Posted : Wednesday, March 2, 2011 7:02:28 PM(UTC)
Applianceaid
Hello,
We would need the complete model number to help you repair your unit. If you have a volt meter we can walk you through your repair.
These units have several very common issues, with a volt meter we could narrow it down relatively quickly.:)
ApplianceRepairLesson.com
Dwight B
#4 Posted : Wednesday, March 2, 2011 7:30:26 PM(UTC)
Dwight B
Originally Posted by: Applianceaid Go to Quoted Post
Hello,
I do have a volt meter. I have an Admiral ADE7005AYW dryer. I got it for free only to find out it does not run. Can I by pass the missinf door switch to test it?
dryergirl
#5 Posted : Thursday, March 3, 2011 9:01:51 AM(UTC)
dryergirl
1104283200
dryergirl
#6 Posted : Thursday, March 3, 2011 9:03:15 AM(UTC)
dryergirl
I think that may be the number of the matching washer. Purchase together.
#7 Posted : Thursday, March 3, 2011 12:25:11 PM(UTC)
Yes this is model number of the washer. We need the model number of the dryer. It suppose to be on the door frame.
#8 Posted : Thursday, March 3, 2011 1:15:53 PM(UTC)
You may want to start th troubleshooting by testing for continuity the thermal fuse (#6 on the diagram).
- The thermal fuse Part number: AP4048636
Applianceaid
#9 Posted : Thursday, March 3, 2011 3:25:52 PM(UTC)
Applianceaid
Hiya,
If you have a volt meter and can read it lets get started, what voltage do we have at the terminal block? Measure from the middle to right, you get____?
measure from middle to left, you get___?
If the unit wont start we are loosing power somewhere, lets start at the beginning, keep it simple.
Attached is a video that explains how to test the dryer cords terminal block.
Terminal Block Video
I'Ll wait for you're reply.
dryergirl
#10 Posted : Tuesday, March 8, 2011 1:23:29 PM(UTC)
dryergirl
Model No. for dryer which won't start is 110.82832100 Can you give me any other suggestions for problem areas since I already replaced the thermal fuse?
Guest (4)
2 Pages12>
