During the agitation cycle, the tub continues to turn in the same direction until water starts to spray out of the top of the machine.
The brake that holds the transmission is FAILING, The only way to repair it correctly is to replace the transmission, Aprox. $200
Thank you. Looks like a replacement is the best option.
