Recently had tremendous ice buildup in freezer section. Replaced, thermostat, temp. sensor and heater. Now all is well, except-- Have frost build up between exit of ice tray and entrance way in door ice dispenser shoot. What could be causing this?
The dorr probably isn't shutting all the way. Common occurance.Suggest replacing ice shoot the door. Nat
Are you talking about the rubber around the inside of the freezer door? Is there a part number?
Sorry for the misunderstanding...I was referring to the little dispenser door part # WR17X11653, it's about $5
Thanks, I'll give it a try.
You really pointed me in the right direction. The dispenser door part appears worn, so I ordered it. I also determined that the solenoid that controls the door was not activating. It was all rusted and dirty. I ordered it as well. Thanks, I'll let you know how it works out.
I have TBH18DAX, but no ice dispenser installed.
Recently, also have begun to get a great deal of frost accumulation in ice cube compartment and left top edge of freezer door.
As far as I know all other systems are go... it's plenty cold. Only issue I'm aware of is fridge compartment door gasket is broken out at the bottom.
Thx!
DL
Originally Posted by: Digital Larry  I have TBH18DAX, but no ice dispenser installed. Recently, also have begun to get a great deal of frost accumulation in ice cube compartment and left top edge of freezer door. As far as I know all other systems are go... it's plenty cold. Only issue I'm aware of is fridge compartment door gasket is broken out at the bottom. Thx ! DL Broken gasket allowing warm moisture laden air inside.
My problem is solved, replaced the parts. As to Larry Digital problem, I would go with replacing the door gasket.
