2 Pages12>
Jerryhere
#1 Posted : Wednesday, October 1, 2008 8:28:00 AM(UTC)
Jerryhere
Recently had tremendous ice buildup in freezer section. Replaced, thermostat, temp. sensor and heater. Now all is well, except--
Have frost build up between exit of ice tray and entrance way in door ice dispenser shoot. What could be causing this?
libertyappl
#2 Posted : Wednesday, October 1, 2008 8:51:48 AM(UTC)
libertyappl
The dorr probably isn't shutting all the way. Common occurance.Suggest replacing ice shoot the door.
Nat
Jerryhere
#3 Posted : Wednesday, October 1, 2008 10:19:32 AM(UTC)
Jerryhere
Are you talking about the rubber around the inside of the freezer door? Is there a part number?
libertyappl
#4 Posted : Wednesday, October 1, 2008 11:44:53 AM(UTC)
libertyappl
Sorry for the misunderstanding...I was referring to the little dispenser door part # WR17X11653, it's about $5
Jerryhere
#5 Posted : Thursday, October 2, 2008 11:49:41 AM(UTC)
Jerryhere
Thanks, I'll give it a try.
libertyappl
#6 Posted : Thursday, October 2, 2008 12:29:58 PM(UTC)
libertyappl
Keep us posted!
Nat
Jerryhere
#7 Posted : Thursday, October 2, 2008 12:41:19 PM(UTC)
Jerryhere
You really pointed me in the right direction. The dispenser door part appears worn, so I ordered it. I also determined that the solenoid that controls the door was not activating. It was all rusted and dirty. I ordered it as well.
Thanks, I'll let you know how it works out.
Digital Larry
#8 Posted : Saturday, October 18, 2008 9:22:44 AM(UTC)
Digital Larry
I have TBH18DAX, but no ice dispenser installed.
Recently, also have begun to get a great deal of frost accumulation in ice cube compartment and left top edge of freezer door.
As far as I know all other systems are go... it's plenty cold. Only issue I'm
aware of is fridge compartment door gasket is broken out at the bottom.
Thx!
DL
icehouse
#9 Posted : Saturday, October 18, 2008 10:00:06 AM(UTC)
icehouse
Thx
DL
Broken gasket allowing warm moisture
laden
air inside.
Jerryhere
#10 Posted : Saturday, October 18, 2008 12:24:09 PM(UTC)
Jerryhere
My problem is solved, replaced the parts. As to Larry Digital problem, I would go with replacing the door gasket.
Temperature Sensor for General Electric GTS22KBPDRCC Frost buildup (Refrigerator & Freezer Repair)
by trm655 11/18/2021 12:53:19 PM(UTC)
LG Freezer Frost Buildup (Refrigerator & Freezer Repair)
by joe475 10/18/2020 7:02:31 AM(UTC)
Kenmore Bottom Freezer Frost Buildup (Refrigerator & Freezer Repair)
by EdBurkett 2/10/2018 7:54:23 AM(UTC)
Refrigerator warm, freezer cold, frost buildup on back of freezer (Refrigerator & Freezer Repair)
by Geoff Hess 8/15/2017 8:31:32 AM(UTC)
Ken more side by side frost buildup on coils (Refrigerator & Freezer Repair)
by Mckelvy2716 8/3/2015 11:17:46 AM(UTC)
Kenmore Side by Side Frost Buildup (Refrigerator & Freezer Repair)
by metolius22 7/27/2015 7:30:58 PM(UTC)
by exptech 10/30/2013 6:36:02 AM(UTC)
Frost buildup problem (Refrigerator & Freezer Repair)
by -Ronin- 6/10/2011 7:04:26 AM(UTC)
frost buildup in freezer, warm below (Refrigerator & Freezer Repair)
by mackisus 9/29/2010 12:21:42 PM(UTC)
frost buildup on freezer wall (Refrigerator & Freezer Repair)
by boulosb 10/30/2009 10:26:08 AM(UTC)
upright freezer frost buildup (Refrigerator & Freezer Repair)
by Paul Keisling 8/11/2009 7:38:23 AM(UTC)
frost buildup in icemaker chute (Refrigerator & Freezer Repair)
by savery 7/14/2009 10:57:05 AM(UTC)
Quick Freeze Area Not Freezing, frost buildup (Refrigerator & Freezer Repair)
by hughes 2/18/2009 5:01:10 AM(UTC)
Excessive frost buildup requiring weekly defrost (Refrigerator & Freezer Repair)
by Joe Cal 9/30/2007 9:21:18 AM(UTC)
2 Pages12>
