whirled
#1 Posted : Thursday, October 2, 2008 7:39:10 AM(UTC)
whirled
I'm troubleshooting the problem of warm fridge and frosting in freezer. How do I check continuity on the bimetal (thermostat); the wires are on the 5-wire harness and very hard to separate. I have already checked the defrost timer and evaporator motor, both are good. anyone please!
libertyappl
#2 Posted : Thursday, October 2, 2008 8:13:08 AM(UTC)
libertyappl
You may need to cut the tape or zip tie to spread the wires better and retape them later. There should be 2 wires on the bi-metal, the easiest way is to clip those wires, leaving long enought to reattach.
I didn't find your exact model breakdown, I found this one tough GD5SHGXLB01.
does you model have a timer or an adaptive defrost timer?
Nat
whirled
#3 Posted : Thursday, October 2, 2008 9:32:46 AM(UTC)
whirled
Nat
Thanks! yes bimetal has two wires that go into 5-wire harness and I'm afraid to yank'em out. I gues I'll cut and check continuity. appliance pro does not even show a bimetal on my model in their breakdown diagram.
