2 Pages12>
thomasthediep
#1 Posted : Tuesday, September 30, 2008 8:45:20 AM(UTC)
thomasthediep
the freezer side is working ok but cooling side is not cooling ,the fan blow air from freezer to cooling side seems ok .i already change defrost timer but the same problem , please give me a help. thanks
libertyappl
#2 Posted : Tuesday, September 30, 2008 9:16:01 AM(UTC)
libertyappl
Check the defrot thermostat and the heater.
Nat
thomasthediep
#3 Posted : Tuesday, September 30, 2008 2:05:54 PM(UTC)
thomasthediep
where is the heater located
thomasthediep
#4 Posted : Thursday, October 2, 2008 8:54:49 AM(UTC)
thomasthediep
but the cooling side is not cooling enough although i adjust the max on the knob of the refrigerator side give me some help please thanks
libertyappl
#5 Posted : Thursday, October 2, 2008 9:02:11 AM(UTC)
libertyappl
The defrost thermostat & heater are behind the rear panel in the freezer. most likely it will be ther thermostat (aka bi-metal)
Nat
thomasthediep
#6 Posted : Thursday, October 2, 2008 9:16:59 AM(UTC)
thomasthediep
i already change defost thermostat but exact the same model is it ok or not it still the same problem thanks
libertyappl
#7 Posted : Thursday, October 2, 2008 9:25:06 AM(UTC)
libertyappl
You changed the defrost thermostat & timer?
thomasthediep
#8 Posted : Thursday, October 2, 2008 9:28:04 AM(UTC)
thomasthediep
yes i already change thermo and timer
libertyappl
#9 Posted : Thursday, October 2, 2008 9:31:46 AM(UTC)
libertyappl
What are the temps on the freezer side & the frig side?
libertyappl
#10 Posted : Thursday, October 2, 2008 9:37:05 AM(UTC)
libertyappl
Your model has a defrost thermostat behind the rear panel in the freezer and a bi-metal near the compressor in the back.
Here's a breakdown on your unit Model TS25AEXHW02
Nat
2 Pages12>
