the freezer side is working ok but cooling side is not cooling ,the fan blow air from freezer to cooling side seems ok .i already change defrost timer but the same problem , please give me a help. thanks
Check the defrot thermostat and the heater. Nat
where is the heater located
but the cooling side is not cooling enough although i adjust the max on the knob of the refrigerator side give me some help please thanks
The defrost thermostat & heater are behind the rear panel in the freezer. most likely it will be ther thermostat (aka bi-metal) Nat
i already change defost thermostat but exact the same model is it ok or not it still the same problem thanks
You changed the defrost thermostat & timer?
yes i already change thermo and timer
What are the temps on the freezer side & the frig side?
Your model has a defrost thermostat behind the rear panel in the freezer and a bi-metal near the compressor in the back. Here's a breakdown on your unit Model TS25AEXHW02 Nat
