Originally Posted by: isomc01 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) With the wires disconnected we do have 120v from tip of wire to ground. The zero volts was from the connection on the board to the ground. I was also trying to say that without the wires connected, I would try to program the oven on but still get 0 volts. But when I do that I get an immediate error message so I am not sure it is even ever turning on. Something shuts it right down.
Also I am a little confused, with the oven power connected, but the oven not turned on should I be reading voltage at the connection of the heating element? Isomc, Yes, and OK, you should have 120 VAC from the wire to chassis ground, we're OK and have one power leg(L1), like our first test. You won't have 120 VAC on the relay board terminals, until the relay closes, based on the input from the control board and key pad assembly. Here is a short description of operation, L1 is power in from the terminal block, goes directly to the relay board and elemnts. L2 is power in from the terminal block, goes directly to the relay board,and powers the L2 side of the elements, when a selection is made. When you program a bake cycle, and there are no fail codes the L2 relay closes on the relay board and sends L2 out to the element, you already have L1 setting on the element, with 240 VAC at the element, it glows red, heats, and cycles off when the chip on the board reads the correct resistance,and cycles the relay to open, and L2 is removed from the circuit, and the element won't heat, until the relay closes again, and it heats again. If I remember correctly, you did replace the ERC/Clock, and relay board ? You may want to recheck your wire harness connections and make sure you did not miss a pin, on the connector, I have seen that occurr. Also check the harnesses at the relay board connections, as well. :) :) :)
