2 Pages12>
roydchristopher
#1 Posted : Monday, February 21, 2011 2:38:06 PM(UTC)
roydchristopher
washer will fill with water, but will not agitate or spin or any other function. help. no previous problems.
roydchristopher
#2 Posted : Tuesday, February 22, 2011 6:51:35 AM(UTC)
roydchristopher
After reading a lot of forum that lid switch may be bad, how do I check this switch?
murderurfriends
#3 Posted : Friday, February 25, 2011 2:52:33 PM(UTC)
murderurfriends
Push down on the lid so it flexes it Gould start if o it needs the slide it gets worn out. Do u hear clicking when opening nd closing the lid?
#4 Posted : Saturday, February 26, 2011 12:43:29 AM(UTC)
Remove the back of the control panel and replace the lid switch, a white plastic item AP4008646
roydchristopher
#5 Posted : Saturday, February 26, 2011 6:22:13 AM(UTC)
roydchristopher
yes, switches click. there is two switches, lid switch and safety switch with fuse.
#6 Posted : Saturday, February 26, 2011 6:41:06 AM(UTC)
The parts site shows two different type switches, the one you see and another white one I mentioned.
If the switches click when the lid is closed, you probably have other problems.
You will need a meter to find the problem, just replacing the switch is probably a waist of money.
To test the switches, you could refer to the schematic and short them out.
You can also go to the timer, remove the cover, and check for burnt contacts. If bad, order it here, AP4026297
roydchristopher
#7 Posted : Saturday, February 26, 2011 4:03:37 PM(UTC)
roydchristopher
ok, checked continuity of lid and safety switches. ok. readjusted switches . washer filled and started to hum. opened lid and turned tub, closed lid and it agitated through cycle, then started to hum again. can't get it to do anything but hum, no cycles of any kind.
#8 Posted : Sunday, February 27, 2011 12:17:20 AM(UTC)
Did you check the timer contacts? Maytag timers have one main power contact that tends to fail. With the schematic and meter, you should be able to verify.
roydchristopher
#9 Posted : Sunday, February 27, 2011 9:56:31 AM(UTC)
roydchristopher
tks, will check
chibluz
#10 Posted : Sunday, February 27, 2011 3:06:56 PM(UTC)
chibluz
Not to tread jack but since I have the same machine and am having similar symtoms I hope I can jump in here. I replaced the lid switch but the machine only fills then just sits. No timer movement. Timer replaced about 5 years ago. Nothing happens when I turn the timer except the water fills and the panel turns off or on.
Any ideas?
Thanks,
JB
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
2 Pages12>
