ruthwilson
#1 Posted : Saturday, February 26, 2011 10:37:29 AM(UTC)
ruthwilson
My washing machine stops between the wash and rinse cycle -- just like it would if the lid were up. However, if I give it a good thump or two with my fist, it moves on. I would like to solve this problem before my temporary fix stops working! Thanks!!!
sidfink43
#2 Posted : Sunday, February 27, 2011 6:17:16 AM(UTC)
sidfink43
Today must be bad lid switch day, you are the second person in a few minutes with this problem. You have the symptoms of a bad lid switch. Check it with a meter, or by-pass it to check it, and if it bad replace it.
ruthwilson
#3 Posted : Sunday, February 27, 2011 10:00:41 AM(UTC)
ruthwilson
Thanks -- from looking at the other postings, I thought it might either be the lid switch (which doesn't sound too bad) or the timer (which sounded ugly). Thanks for your help!
sidfink43
#4 Posted : Sunday, February 27, 2011 11:16:54 AM(UTC)
sidfink43
Glad to help, let us know how it turns out.
Guest (4)
Washer stops between cycles (Washer Repair)
by 54591974 2/11/2013 7:04:07 AM(UTC)
Washer Stops Between Cycles (Washer Repair)
by polishplumber 12/27/2012 4:05:28 PM(UTC)
