Oh, yeah,
I forgot to ask the rather rudimentary question of how best to take apart the unit with minimum fuss to access the trouble area (probaly the pump/drain?)
Thanx HAZ
Thanx HAZ Haz, Remove the front panel, the drain pump / hose are located on the left side of the cabinet. Remove the two screws on the bottom of the panel, and lower/remove. *** Of course, you need to UN PLUG the power cord,or turn off the power to the unit, FIRST. *** Good Luck, :) :) :)
