I ordered a fan motor only replacement part #AP4140906 and two new gromments, instead of the complete fan motor and housing, for my 2004 Samsung model #RS2630SH. My ? is how detailed of a job this is gonna be or just a simple repacement into the original housng to restore this compressor componets cooling gem.
Thanks, Frank
Originally Posted by: buckit  I ordered a fan motor only replacement part #AP4140906 and two new gromments, instead of the complete fan motor and housing, for my 2004 Samsung model #RS2630SH. My ? is how detailed of a job this is gonna be or just a simple repacement into the original housng to restore this compressor componets cooling gem.
Thanks, Frank Frank, Not that major a repair, The best way, is to remove the whole assembly, Be careful, there's a lot of sharp edges, And that housing is a "snap" fit into the base of the compartment. The condenser Fan is located in the middle of machine compartment. It cools down the subcondenser and the compressor. 1. Lift up the rib under the motor support. 2. Pull the support motor.Not a lot if information from the service manual.Good Luck, :) :) :)
Thanks, Frank Thanks Joe, your advise is what I was hoping to hear.
Originally Posted by: buckit  Thanks Joe, your advise is what I was hoping to hear. Our pleasure to help, Drop us a line when you're done, and let us know how you did. :) :) :)
Thanks, Frank Joe, How do remove the fan blade to remove and replace the defective motor I inquired about installing? Thanks Frank(buckit)
Originally Posted by: buckit  Joe,
How do remove the fan blade to remove and replace the defective motor I inquired about installing? Thanks Frank(buckit) Frank, As I mentioned, not a lot of service information, As best I can tell, and remember, The fan blade is held in place by a small metal spring clamp, on the center hub of the fan blade, or is a pressure fit and will pull off. The fan motor itself is mounted to the support assembly by 2 rubber grommets, one on each side of the motor shaft/housing in the center of the motor itself. I guess I mis understood your original question. :confused: :confused: :confused:
Joe M.
Thanks again Joe the new motor was a breeze to replace as you had stated in your first reply, The fan blade was the only problem I had and after removing the spring clip and putting a squirt of wd-40 on the shaft it finally slid off without breaking. The new Samsung fridge fan motor is now running like the new one it is. Thanks so much
Frank(buckit):) :) :)
Frank(buckit):) :) :) Frank, I had a feeling you'd do fine, We're glad you're up and running. It was a pleasure to help. Good Luck, :) :) :)
