buckit
#1 Posted : Friday, February 25, 2011 7:20:59 AM(UTC)
buckit
I ordered a fan motor only replacement part #AP4140906 and two new gromments, instead of the complete fan motor and housing, for my 2004 Samsung model #RS2630SH. My ? is how detailed of a job this is gonna be or just a simple repacement into the original housng to restore this compressor componets cooling gem.
Thanks,
Frank
Joe / APP Team
#2 Posted : Friday, February 25, 2011 8:02:16 AM(UTC)
Joe / APP Team
Thanks,
Frank
Frank,
Not that major a repair,
The best way, is to remove the whole assembly,
Be careful, there's a lot of sharp edges,
And that housing is a "snap" fit into the base of the compartment.
The condenser Fan is located in the middle of
machine compartment. It cools down the subcondenser
and the compressor.
1. Lift up the rib under the motor support.
2. Pull the support motor.
Not a lot if information from the service manual.
Good Luck,
buckit
#3 Posted : Friday, February 25, 2011 8:16:07 AM(UTC)
buckit
Thanks,
Frank
Thanks Joe, your advise is what I was hoping to hear.
Joe / APP Team
#4 Posted : Friday, February 25, 2011 9:50:40 AM(UTC)
Joe / APP Team
Our pleasure to help,
Drop us a line when you're done, and let us know how you did.
buckit
#5 Posted : Wednesday, March 2, 2011 11:14:36 AM(UTC)
buckit
Thanks,
Frank
Joe,
How do remove the fan blade to remove and replace the defective motor I inquired about installing? Thanks
Frank(buckit)
Joe / APP Team
#6 Posted : Wednesday, March 2, 2011 1:58:16 PM(UTC)
Joe / APP Team
Joe,
Frank(buckit)
Frank,
As I mentioned, not a lot of service information,
As best I can tell, and remember,
The fan blade is held in place by a small metal spring clamp, on the center hub of the fan blade, or is a pressure fit and will pull off.
The fan motor itself is mounted to the support assembly by 2 rubber grommets, one on each side of the motor shaft/housing in the center of the motor itself.
I guess I mis understood your original question.
:confused: :confused: :confused:
buckit
#7 Posted : Thursday, March 3, 2011 2:33:15 PM(UTC)
buckit
Joe M.
Thanks again Joe the new motor was a breeze to replace as you had stated in your first reply, The fan blade was the only problem I had and after removing the spring clip and putting a squirt of wd-40 on the shaft it finally slid off without breaking. The new Samsung fridge fan motor is now running like the new one it is. Thanks so much
Frank(buckit):) :) :)
Joe / APP Team
#8 Posted : Friday, March 4, 2011 5:28:33 AM(UTC)
Joe / APP Team
Joe M.
Frank,
I had a feeling you'd do fine,
We're glad you're up and running.
It was a pleasure to help.
Good Luck,
Guest (4)
Fan motor replacement manitowoc (Refrigerator & Freezer Repair)
by Guest 5/27/2023 4:35:45 AM(UTC)
Kenmore Condenser fan motor replacement woes.. (Refrigerator & Freezer Repair)
by shippey 8/20/2011 4:55:02 AM(UTC)
Jenn-Air Evap Fan motor replacement (Refrigerator & Freezer Repair)
by dmeredith@rocketmail.com 9/10/2010 9:41:02 AM(UTC)
Condenser Fan Motor Replacement P/N 240397101 shaft will not hold the fan straight (Refrigerator & Freezer Repair)
by racerjack 5/5/2010 2:35:27 PM(UTC)
GE Evap fan motor replacement (Refrigerator & Freezer Repair)
by JoeW 2/29/2008 1:33:51 AM(UTC)
