Jawasky
#1 Posted : Thursday, February 24, 2011 8:49:58 AM(UTC)
Jawasky
What is best way to install door seal on my dishwasher? Part number is AP4113184. Part is made by Whirlpool.
Joe / APP Team
#2 Posted : Thursday, February 24, 2011 11:35:36 AM(UTC)
Joe / APP Team
Jawasky,
Basically, it's a "friction" fit.
See below,
DOOR GASKET
The Door Gasket provides a seal between the Door and
the Tub.
Removal
1. Open Door.
2. From either corner, pull gasket up and out of tub
recess.
Replacement
1. To ease installation, wet gasket with water.
2. Starting in the lower right corner, Gently work gasket
into the recess of Tub up the right side.
3. With other end, place gasket flush with the Tub in
lower left corner.
4. Gently work gasket in to the recess of the Tub, up the
left side, and across the top.
Good Luck,
Jawasky
#3 Posted : Friday, February 25, 2011 7:17:12 AM(UTC)
Jawasky
Thanks for advice. Now I will order part and try to install it.
Joe / APP Team
#4 Posted : Friday, February 25, 2011 7:32:17 AM(UTC)
Joe / APP Team
It's a pretty simple operation,
You'll do fine.
Good Luck,
