What is best way to install door seal on my dishwasher? Part number is AP4113184. Part is made by Whirlpool.
Originally Posted by: Jawasky  What is best way to install door seal on my dishwasher? Part number is AP4113184. Part is made by Whirlpool. Jawasky, Basically, it's a "friction" fit. See below, DOOR GASKET
The Door Gasket provides a seal between the Door and the Tub.
Removal
1. Open Door. 2. From either corner, pull gasket up and out of tub recess.
Replacement
1. To ease installation, wet gasket with water. 2. Starting in the lower right corner, Gently work gasket into the recess of Tub up the right side. 3. With other end, place gasket flush with the Tub in lower left corner. 4. Gently work gasket in to the recess of the Tub, up the left side, and across the top.
Good Luck, :) :) :)
Thanks for advice. Now I will order part and try to install it.
Originally Posted by: Jawasky  Thanks for advice. Now I will order part and try to install it. It's a pretty simple operation, You'll do fine. Good Luck, :) :) :)
