cberrya6e
#1 Posted : Monday, September 29, 2008 9:51:47 AM(UTC)
cberrya6e
Any help here would be appreciated. Selecting LITE on any of the burners causes the igniter on the RF (and only on the RF) burner to click. No gas flows in the RF burner (unless that knob is also turned on). Can use a match to manually light any of the burners, so gas flow is not an issue. What should I be looking at or testing?:confused:
The oven is a GE Profile, model number JGB908SEKSS, purchased 2 1/2 years ago.
Regards,
Chuck
Ike Sucked!
libertyappl
#2 Posted : Monday, September 29, 2008 10:03:38 AM(UTC)
libertyappl
Sounds like the burner ignitor(s) are shorted out each burner has one that attachs to the valve.
cberrya6e
#3 Posted : Monday, September 29, 2008 10:15:26 AM(UTC)
cberrya6e
Thanks so much for the quick reply!
In that case, would selecting Lite on the associated shorted igniter still result in another igniter clicking?
How do I troubleshoot this issue? Thanks for the help.
