I have a Whirlpool Gold double oven. The top oven will not heat up. This problem started after I put it through a self cleaning cycle. The bottom oven works fine. Could the problem be the thermostat?
Test proceedure Perform the following checks and adjust/repair as needed: 1. Check to see if the door opens beyond a 90º angle. 2. Check for damage to the door gasket. 3. Check the oven venting (obstruction in the vent or smoke eliminator, crushed, separated or incorrectly assembled vent, etc.). 4. Check the Blower Fan to see if there is a misalignment. 5. Check for the correct (part number)TOD. 6. A power interruption during use can and will cause the TOD or control fuse to open. 7. The oven should not be installed in a corner. 8. If all these check OK, replace the blower assembly. Hope this helps Nat
