The freezer door likes to stay ajar about a half inch. I figured the self closer needed adjustment. When I took the top hinge off (three screws) there was no tension at all. There seems to be a broken plastic or nylon piece on top of both hinges (although the fridge side still closes OK) and I notice a small hole, maybe 1/4 inch, on the top of each door, next to the hinge. I figured there is something that slides onto the hinge pin and locks into that hole. But I see nothing in the parts diagrams.
This fridge is falling apart but as far as a fridge freezer goes, it runs fine. I need new drawers and guides, new handles and the water dispense leaks, but it cools and freezes great. Unless the door stays ajar. Then everything defrosts!
Did you check the bottom hinge o the door? Nat
