207 Pages«<111112113114115>»
elpiar
#1121 Posted : Monday, February 14, 2011 8:48:07 AM(UTC)
elpiar
i have Amana abc2037dtb and I think the defrost timer is electronically controlled from the board. How do I test the defrost cycle on this unit?
I believe the control boards is AP4366538
What are the terminals I can test?
howie douglas
#1122 Posted : Monday, February 14, 2011 9:38:42 AM(UTC)
howie douglas
this is the first time i hear that, what generation and what brand is it? So i can avoid it:D
#1123 Posted : Monday, February 14, 2011 12:28:45 PM(UTC)
What exactly is wrong with your refrigerator?
lizzygrace
#1124 Posted : Monday, February 14, 2011 9:54:35 PM(UTC)
lizzygrace
sorry, wrong place....
bobpete84
#1125 Posted : Wednesday, February 23, 2011 4:45:29 PM(UTC)
bobpete84
Good evening,
I believe my Kenmore fridge (model # 2537179210A mfg 02/02) is having a defrost issue. The freezer works great and the fridge does not. The fans visibly operate, however there is rapid ice accumulation in the vents toward the bottom of the freezer. I'd like to check the defrost heater, but can't seem to disconnect the ice maker to pull off the back panel. Any advice? I understand that once off, a little snow is okay, no snow is bad and too much snow is verification of a faulty defrost heater and/or defrost timer, correct? Any help is appreciated. Thank you very much.
Bob
Raleigh, NC
jojosdad
#1126 Posted : Thursday, February 24, 2011 11:57:21 AM(UTC)
jojosdad
I have the above model fridge and the fresh food section is 57 while the freezer is showing 15. I tried the troubleshooting method in the first post in this thread but can't find the defrost timer control. Can you help me?
thanks
#1127 Posted : Thursday, February 24, 2011 12:57:27 PM(UTC)
Bob,
The ice maker is secured with the three screws, two on the top of the ice maker and one under it. The wire harness plug has two latches, one on the top of the plug and the other one on the bottom. Just push them together and pull the plug out.
Quote:
...I understand that once off, a little snow is okay, no snow is bad and too much snow is verification of a faulty defrost heater and/or defrost timer, correct?...
Yes, this is correct. You can use the instructions on the very first page in this thread.
- The defrost timer Part number: AP2111929
- The defrost thermostat Part number: AP2150133
- The defrost heater Part number: AP2150139
#1128 Posted : Thursday, February 24, 2011 1:01:32 PM(UTC)
thanks
Have you removed the rear panel in the freezer to check the condition of the evaporator coils?
Post the results please.
Here are the breakdown diagrams and Replacement parts for General Electric GTS22IBMBRCC Refrigerator | AppliancePartsPros.com
chrismalm
#1129 Posted : Friday, February 25, 2011 2:54:52 PM(UTC)
chrismalm
Hi Gene,
I have a Maytag MBB2256GES. I melted the glacier in back of my freezer, manually turned my defrost timer, and heard the drops sizzling on the heater. I received my timer (Control diag #12) and timer pan (Control diag #5) today.
I don't want to break anything. Can you give me the basic order of disassembly ? I tried lamp lense, rear control cover, temp control belt, timer pan. I think I need to remove the front cover also, but I don't see how.
Thanks for any help you can give me.
Chris
#1130 Posted : Friday, February 25, 2011 6:10:28 PM(UTC)
Chris,
The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for MAYTAG MBB2256GES REF - BOTTOM MOUNTS | AppliancePartsPros.com
File Attachment(s):
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by allemich 4/19/2009 8:02:07 PM(UTC)
