cquaglin
#1 Posted : Wednesday, February 23, 2011 11:27:34 AM(UTC)
cquaglin
first the dishwasher handel broke. we replaced that and it worked fine for about 2 weeks. then out of the blue the digital screen would not work correctly. some numbers will pop up, some parts of the numbers will not pop up. when i press the normal wash or heavy wash buttons nothing pops up on the screen. none of the wash cycles will run at all. do i need a new motherboard/ faceplate? also does it matter what side the white wires and black wired are attacted to or can it be flipped? it looks like it doesnt matter since they just go into an identical 125v 15a relay. can you send a set of prints with your reply? please let me know. thanks -chris
magician59
#2 Posted : Wednesday, February 23, 2011 12:15:54 PM(UTC)
magician59
Re-check your connections to the door switch. Also check the electrical connections under the machine, to make sure there aren't any loose or disconnected wires. Here's a link to the wiring schematic for your dishwasher.
Wiring information replacement parts for MAYTAG MDBH965AWW DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
