first the dishwasher handel broke. we replaced that and it worked fine for about 2 weeks. then out of the blue the digital screen would not work correctly. some numbers will pop up, some parts of the numbers will not pop up. when i press the normal wash or heavy wash buttons nothing pops up on the screen. none of the wash cycles will run at all. do i need a new motherboard/ faceplate? also does it matter what side the white wires and black wired are attacted to or can it be flipped? it looks like it doesnt matter since they just go into an identical 125v 15a relay. can you send a set of prints with your reply? please let me know. thanks -chris
