2 Pages12>
STEVE DOE
#1 Posted : Wednesday, October 24, 2007 10:02:00 AM(UTC)
STEVE DOE
The keypad lock is enabled (green lock light on) and won't reset when holding in the button for 4 seconds per the manual's direction. All keys are literally locked rendering my machine useless! I read about a similar issue but with different brand- said new console was probably needed? Can you please advise what part number is needed for my problem?
#2 Posted : Wednesday, October 24, 2007 3:25:44 PM(UTC)
Hi Steve
If the control senses one or more pads stuck, it stops the dishwasher and locks out the key pad. In order ti fix it the console has to be replaced.
- The part number for the new white console AP3885210
Good luck.
STEVE DOE
#3 Posted : Saturday, November 3, 2007 3:12:29 PM(UTC)
STEVE DOE
Help!
I replaced the console but the problem did not go away-the key lock is still on. Do you think I need a board?
Please list part number of suspected cause.
Thanks,
S
#4 Posted : Monday, November 5, 2007 9:21:02 AM(UTC)
Hi Steve
This is very unusual but looks like the control board has to be replaced too.
- The part number for the new control board AP3961536
STEVE DOE
#5 Posted : Wednesday, September 24, 2008 7:48:29 AM(UTC)
STEVE DOE
Hi Gene,
Now when I push the start button, nothing happens only the buttons on the left seem to work. What could be the problem?
#6 Posted : Wednesday, September 24, 2008 1:30:19 PM(UTC)
Steve,
How did you end up back in November? Which parts did you replace?
STEVE DOE
#7 Posted : Friday, September 26, 2008 10:55:21 AM(UTC)
STEVE DOE
Gene,
I had to replace the control board 2x already- I just replaced it a month ago and used it only 1 time since. It is almost like I have a lemon dishwasher. Never needed to replace the new white console AP3885210. What do you think is wrong?
Thanks,
#8 Posted : Friday, September 26, 2008 11:56:09 AM(UTC)
Originally Posted by: STEVE DOE Go to Quoted Post
...only the buttons on the left seem to work...
Steve,
What are these buttons?
Did you check the door switches?
STEVE DOE
#9 Posted : Saturday, September 27, 2008 4:06:03 PM(UTC)
STEVE DOE
it is almost as if most of the buttons on the keypad (cycles, options, Start buttons) dont work. Door latches ok.
thanks
STEVE DOE
#10 Posted : Tuesday, September 30, 2008 9:48:02 AM(UTC)
STEVE DOE
Hi guys, I'm no expert but believe I need a new white console AP3885210 since not alll my keypad works.
2 Pages12>
