HemiRick
#1 Posted : Tuesday, February 22, 2011 12:03:28 AM(UTC)
HemiRick
Whirlpool defrost timer clicks repeatedly, and freezer is all frosted up....It's the one with the adaptive defrost timer and I've done the cut resistor 10 trick to disable the adpative mode....What's wrong with this fridge?
ThanksRick
HemiRick
#2 Posted : Tuesday, February 22, 2011 12:12:30 AM(UTC)
HemiRick
The model num is ED5VHGXML13 there is no tech sheet for this fridge how do I test it.
#3 Posted : Tuesday, February 22, 2011 1:39:11 AM(UTC)
Replacement parts for WHIRLPOOL ED5VHGXML13 REFRIGERATOR | AppliancePartsPros.com
See the attachment for the tech sheet
Put the unit back to the way it was and try to force a defrost cycle.
The compressor and fans will shut off when in defrost.
If it does not heat up then unplug the unit.
Measure the defrost heater, should be approximately 20 ohms.
Measure the defrost thermostat, should be 0 ohms when frozen
If both are OK odds are the defrost board is toast.
If it does heat up then the defrost board is toast.
Be careful that you do not burn your fingers.
File Attachment(s):
ED5VH.pdf (569kb) downloaded 8 time(s).
HemiRick
#4 Posted : Tuesday, February 22, 2011 4:26:36 PM(UTC)
HemiRick
Ok I took it apart, defrosted it and tested things. The heater coil is 23 ohms the defrost bimetallic was open cold and I've shorted the wires temporarily.
Can't force it to go into defrost mode. Have put it back together with voltmeter leads connected to heater coil, if and when it starts clicking again, I'm going to check the volt meter. Think I need a ADC and a defrost bimetallic. How come your prices are the highest on the web for parts? Other sites have these parts for $25 less, do you price match?
#5 Posted : Wednesday, February 23, 2011 5:27:14 AM(UTC)
[COLOR="DarkRed"]How come your prices are the highest on the web for parts? Other sites have these parts for $25 less, do you price match?[/COLOR]
I cannot really say as I do not work for ApplianceartsPros, you would have to contact their parts people.
I can tell you that this is the first time I can remember anyone saying the parts are too expensive.
Could be the parts you are looking at are third party parts and not made by Whirlpool but I am just guessing.
