2 Pages<12
Joe / APP Team
#11 Posted : Wednesday, February 16, 2011 6:16:43 AM(UTC)
Joe / APP Team
Originally Posted by: drburdi Go to Quoted Post
Yes I had turned off the ice while assemble with out to install the tray. Turned on and 1 set of cubes made but no water after that. Is there a way of testing the tray sensor or bypassing it to see if things will work so I would know that the sensor is bad?
What is the function of the sensor?
DR,
No,
You can't bbypass the tray sensor, it is a resistance circuit ( control board is looking for a specific ohms reading at a certain temperature) If you bypass it. you'll get a false reading and the control will not function properly, if at all.
If you have a meter you can check the resistance readings:
Room Temperature(70 dgrs.) resistance should be 1093 ohms
Freezing Temperature(32 dgrs) resistance should be 3933 ohms
Frozen Temperature(0 dgrs) resistance should be 13290 ohms.
The function of the sensor, is to inform the control that the tray/ice has reached proper temperature, and it's time to rotate and drop the cubes into the bin.
But before we go too far,
Check and make sure the shut off arm(lever) is in the fully dropped position, and not stuck somewhere in between.
Press and hold the black rubber button( test switch) for 2 or 3 seconds, and see if the ice maker runs a cycle.
We'll keep an eye out for your response,
:cool: :cool: :cool:
drburdi
#12 Posted : Friday, February 18, 2011 8:33:17 PM(UTC)
drburdi
Sorry I did not get back sooner but could not do anything with problem for a couple days.
Pressed button on the ice tray mechanism and noticed that the tray turned, then twisted the ice out. In doing so it busted the repaired tray. Have to get new one. Wonder if it is twisting too much or just that the tray gets fatigued and eventually breaks off the round post. Any thoughts?
Noticed that only when I press the button does the ice get dumped and then water fills up the broken tray. Hard to determine if everything is working to recycle repeatedly for more ice since the cycle seems to work only when I press the button.
I need to order all the parts and hopefully everything else works unless you suspect that I need something more than the dispenser assembly and ice tray. Do you?
Joe / APP Team
#13 Posted : Monday, February 21, 2011 10:17:46 AM(UTC)
Joe / APP Team
DR,
I haven't run into that before.
I didn't work on a whole lot of these units, but what I have here, and what I remember, and your post,
First thing, order another tray and tray sensor, also check and reduce the temperature in the freezer compartment(reccomended temperature is 3 to 5 degrees).
We know the control head is working properly, because it works in the test mode.
We know the housing and other components are OK, because it does attempt to release the cubes.
But, if that sensor has wrong resistance or the freezer temperature is too cold, I can imagine that tray getting too cold and brittle, and breaking, as you described.
Good Luck,
drburdi
#14 Posted : Wednesday, March 2, 2011 4:46:29 AM(UTC)
drburdi
Put new tray in along with turning down the temp one notch. Ice cubes are formed but does not dump unless I press the test button. Waited several days while occasionally pressing button to dump ice tray. Only get more cubes this way. Would the sensor that sits in the tray cause the tray to not dump automatically?
Anything else that would cause this?
Joe / APP Team
#15 Posted : Wednesday, March 2, 2011 6:37:25 AM(UTC)
Joe / APP Team
DR,
Now that you've reset the temperatures, and the tray does not break when it twists, and the ice maker operates in the test mode.
Yes, your tray sensor, is most likely the problem, it does control the ice maker rotation and dump procedure.
As I stated before, there were problems with that sensor a few years ago.
That's the next logical, repair.
2 Pages<12
