allen9258
#1 Posted : Monday, September 22, 2008 7:30:48 PM(UTC)
allen9258
washer will fill and wash clothes but only in warm cold setting will not fill in the cold water setting after water has drained from the wash cycle then there is nothing water will not fill enter the tub and i am not able to rinse the clothes any idea what is wrong?
libertyappl
#2 Posted : Monday, September 22, 2008 7:38:15 PM(UTC)
libertyappl
Turn your main water shutoffs off and remove the hoses. Look inside the valve for any debris, clean carefully with a q-tip or old toothbrush if anything in there. If you don't see anything replace the valve the cold side is probably out.
Nat
allen9258
#3 Posted : Thursday, September 25, 2008 2:29:38 AM(UTC)
allen9258
is the hot and cold vale one complete unit
libertyappl
#4 Posted : Thursday, September 25, 2008 8:11:50 AM(UTC)
libertyappl
Yes, but some times one side goes out or the cold side gets plugged with particles from the water supply lines.
Nat
#5 Posted : Thursday, September 25, 2008 10:53:13 AM(UTC)
allen9258,
You opened two threads (one here and another one here http://forum.appliancepartspros...-start-up.html#post35717) claiming two different problems with your washer. We would like to know what the real problem is. Does it fill up with water and then doesn't go further or it does wash and just stops at the rinse cycle? Very confusing.
allen9258
#6 Posted : Friday, September 26, 2008 5:46:16 AM(UTC)
allen9258
sorry for this but 2 different problems with 2 different washers.
