Ray Clow
#1 Posted : Wednesday, September 24, 2008 8:59:55 AM(UTC)
Ray Clow
Top oven is NOT igniting. The pilot light is on. The broiler burner does ignite. I have wiped the thermostat bar/sensor off with a damp sponge AND have wiped the pilot light sensor and relighted the pilot and still NO ignition.
The Sears website still lists this model but shows almost all parts as discontinued.
All help and or assistance will be appreciated as we really do like this appliance.
Thank you in advance, Ray Clow
libertyappl
#2 Posted : Wednesday, September 24, 2008 9:33:35 AM(UTC)
libertyappl
Ray,
You may want to try to clean the bake burner bar to make sure nothing is obstructing the gas flow. A good old fashioned pipe cleaner does wonders. Gene has a post(several actually) where he shows how he had drilled additional holes in a burner bar to make it work, not sure if it will help your stove or not. If you can locate the exact problem and post a picture of the part I may be able to cross reference it to a substitute part.
Nat
Ray Clow
#3 Posted : Thursday, September 25, 2008 6:59:25 AM(UTC)
Ray Clow
Nat,
Thank you for your response. Your suggestion may help. In the past when turned on or re-turned the unit would make a groan like a valve was opening and then you could hear the burner turn on(produce flame). I do NOT hear this groan sound (opening of the valve) now!!! I will see if I can take and post a picture sometime today.
Ray
Ray Clow
#4 Posted : Monday, September 29, 2008 8:46:58 AM(UTC)
Ray Clow
Nat,
Here are 3 pictures of Kenmore 103.7966645. #1 is front view of upper ovenUserPostedImage The #2 is inside view of upper oven with racks removed showing pilot and burner assembly - UserPostedImage and #3 UserPostedImage is like #2 also showing the thermostat sensor... I hope this works as I do not know if the images are in this message. Let me know (if this does not work) how to include images in a post or I can attach in an email to you...
Thank you, Ray Clow
libertyappl
#5 Posted : Monday, September 29, 2008 9:26:49 AM(UTC)
libertyappl
Ray,
The pictures didn't show up, use the "go advanced" button below and upload the pictures there see if that will owrk.
Nat
Ray Clow
#6 Posted : Tuesday, September 30, 2008 8:06:58 AM(UTC)
Ray Clow
Nat,
Here are the 3 pictures as attachments as stated in last post. If this does not work, let know and I will send as attachments to an email to libertyapplservice@yahoo.com.... Hope this works!!!
Ray
Ray Clow attached the following image(s):
Ray Clow
#7 Posted : Tuesday, October 7, 2008 1:53:48 PM(UTC)
Ray Clow
Nat,
Did you visit and see the pics I sent? Any luck?
I have found the original part numbers for of the Kenmore 103.7966645:
Flame Switch with pilot light - 108659
Thermostat-Cook & Keep - 114262
Fluoresent Holder bracket, right - 109698 (right is 109699)
I hope this helps you find either or substitute parts...
Thanks again,
Ray Clow
libertyappl
#8 Posted : Tuesday, October 7, 2008 2:10:21 PM(UTC)
libertyappl
Ray,
Searspartsdirect has a replacement for the flame switch, part # 315115 I haven't found the other yet. Still looking.
Nat
Gas oven not igniting (Oven Repair (including Ranges and Cooktops))
by buggee 7/22/2009 4:54:00 AM(UTC)
Kenmore Gas Oven Not Igniting With New Igniters. (Oven Repair (including Ranges and Cooktops))
by Fix It Dad! 11/25/2008 6:56:38 PM(UTC)
