corporate download
#1 Posted : Monday, September 22, 2008 3:32:47 PM(UTC)
corporate download
I have a frigidaire portable dishwasher that won't drain once it runs a cycle with really hot water. If I let it cool down, I can start a new cycle, which will kick on the pump and drain it out. If I do the same but don't let it cool enough, pump only comes on briefly then cuts out again. any thoughts?
#2 Posted : Tuesday, September 23, 2008 10:31:59 AM(UTC)
The model number you posted does not come up. Is it American model?
corporate download
#3 Posted : Tuesday, September 23, 2008 10:37:25 AM(UTC)
corporate download
a canadian model. a portable, 24" wide, says only "frigidaire quiet plus" on the door.
#4 Posted : Tuesday, September 23, 2008 10:59:21 AM(UTC)
Possible the problem is a bad drain pump, if there is a separate pump. Unfortunately there is no on-line information for non American models.
Guest (4)
