Here is your parts breakdown
Replacement parts for WHIRLPOOL LTE5243DT5 WASHER/DRYER LAUNDRY SYSTEM | AppliancePartsPros.comHere is a manual, it should be close to your unit.
Service Manual L-56 Large Capacity Thin Twin Service Manual - ApplianceDigest.comYou will have to join the site to download the manual but it is well worth it.
[COLOR="DarkRed"]spins,turns.....but there is no heat is it a heating element?[/COLOR]
Cannot say, you will have to do more trouble shooting.
[COLOR="DarkRed"]how much does it normally cost to fix if i have the part is it easy to fix yourself?[/COLOR]
Depends what if anything is needed, see the parts listing for prices.
First thing to check is the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
The motor etc. uses half the line while the heating coil requires the full 240 volts.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!! [/COLOR]
Next would be the heater and the thermal fuse.
If the fuse is blown then check/clean your vent system as it is the most common cause of the fuse blowing.
If the vent is OK get back to us as there are other things you should check before replacing it.
