Niko33
#1 Posted : Thursday, February 17, 2011 3:41:58 AM(UTC)
Niko33
My GE Artica side by side refrigerator has developed a problem where the water dispenser will fail intermittently and the ice dispenser has failed completely. The unit still makes ice. The flapper will still open. Occasionally when the water dispenser will not work and you open the refrigerator door you will see HRS flashing in the display window. I have seen where there was a GE recall mentioned but have not been able to find a copy of the recall letter to verify. I have been happy with my GE appliances so far and would like to get the problem corrected before it becomes a more serious problem.
Jeff / APP Team
#2 Posted : Thursday, February 17, 2011 9:06:26 AM(UTC)
Jeff / APP Team
I did some research on this and it seams as if you have a failing mother board. Other people with this problem repaired theirs with this part. Here is the part number along with a link to the parts diagram. Hope this helps.
Part number: AP4436216
dincon
#3 Posted : Monday, February 28, 2011 6:29:07 AM(UTC)
dincon
I had the same intermittent problem that became less intermittent and more constant. I installed a new control board and the problem remained. The ice dispenser did engage just once but only once. I haven't figured out the solution but the next step is to replace the dispenser unit. I'll follow up with the solution when ever I find it.
Guest (4)
