mbwolk
#1 Posted : Wednesday, February 16, 2011 2:58:10 PM(UTC)
mbwolk
I had a broken latch and opened the control panel to reveal the door mechanism. I replaced it, but found that the about half of the screw bosses on the control panel had snapped during the opening process. I released the ribbon cable in order to remove control panel and got a small shock (I know, I should have disconnected the power).
When I put the control panel back on, it was dead - no LEDs. I figured I had either fried the control panel or the main board. I ordered a replacement control panel and put it in (the power was off this time), but no luck.
Did I blow the main board? Is there a fuse or reset somewhere that might have tripped? Any suggestions?
#2 Posted : Thursday, February 17, 2011 2:20:33 AM(UTC)
Many of theses units do have a fuse on or attached to the control board.
Will need a complete model number to confirm this.
mbwolk
#3 Posted : Thursday, February 17, 2011 3:33:10 AM(UTC)
mbwolk
Model No. KUDP01ILWH2
Ser. No. FP2703611
Thanks for your help.
#4 Posted : Thursday, February 17, 2011 4:16:38 AM(UTC)
Replacement parts for WHIRLPOOL KUDP01ILWH2 DISHWASHER | AppliancePartsPros.com
Yes it does have a fuse (Item 6 in Section 2)
If it is blown be sure to use the new harness that comes with the fuse.
