EricMN
#1 Posted : Monday, September 22, 2008 1:02:21 PM(UTC)
EricMN
I have a Whirlpool gold oven which is less than 2 years old. The touch pad went crazy on us and I was told to replace the control panel. I replaced it and nothing changed. I was then told to replace the touch pad. I replaced it and everything works but the bake button and the cook time buttons. I've called Whirlpool which did not help.
Can anyone help me? I've put $300 dollars into a $980 stove. It's the last whirlpool anything I'll buy.
Eric
libertyappl
#2 Posted : Monday, September 22, 2008 1:05:01 PM(UTC)
libertyappl
Check your connections making sure they are firmly attached and no corrosion on them. If there is any corosion use a pencil eraser to clean them making sure not to bend them.
Nat
EricMN
#3 Posted : Monday, September 22, 2008 1:30:03 PM(UTC)
EricMN
Which connections? On the control panel hookup? Is there anywhere else I should be checking?
Thanks for the reply.
libertyappl
#4 Posted : Monday, September 22, 2008 2:01:41 PM(UTC)
libertyappl
Sorry, yes check the control panel connections. That's the main part I will try to look at your breakdown again and see if I can find anything else.
Nat
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
Whirlpool Oven WFE770H0FZ2 (Oven Repair (including Ranges and Cooktops))
by Guest 2/9/2024 7:03:09 AM(UTC)
Whirlpool Oven GBD307PDS7 Shuts down and Upper Blower fan does NOT work (Oven Repair (including Ranges and Cooktops))
by rswilson1844 12/3/2023 11:18:33 AM(UTC)
Whirlpool Oven Cooling Fan (Oven Repair (including Ranges and Cooktops))
by Tfastle 11/21/2023 9:59:51 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Whirlpool oven WFE505W0HB2 (Oven Repair (including Ranges and Cooktops))
by Guest 1/7/2023 5:44:02 AM(UTC)
Whirlpool oven broil element doesn't go off and code F3 E2 (Oven Repair (including Ranges and Cooktops))
by Right_to_Repair 3/29/2022 1:54:22 PM(UTC)
Whirlpool oven approximately (2006) (Oven Repair (including Ranges and Cooktops))
by Guest 2/28/2022 3:02:09 PM(UTC)
Whirlpool oven shuts off overnight (Oven Repair (including Ranges and Cooktops))
by Guest 4/15/2021 3:53:14 PM(UTC)
Kitchen Aid/whirlpool oven does not light on the first try (Oven Repair (including Ranges and Cooktops))
by Deintinis 11/22/2020 7:42:29 AM(UTC)
Whirlpool oven won’t stay lit (Oven Repair (including Ranges and Cooktops))
by jc0786 11/15/2020 7:11:47 AM(UTC)
Whirlpool Oven - RBS307PVS03 - Fuse for front control (Oven Repair (including Ranges and Cooktops))
by lmagdaleno 11/8/2020 11:50:57 AM(UTC)
