Quit Running while on spin cycle. Wife put it to extra rinse cycle and began to fill again,it quit filling. Have tried all cycles, nothing now works. Power OK, Fuse OK, It will fill if I short the wires together at control for water level. No power at motor. Thanks
Locate the water level switch (#21 on the diagram). Note how the wires are connected to the terminals. Remove the wires and check for continuity across the terminals #7 & #6 while the washer is full of water. If there is no continuity, check the air pressure hose by disconnecting it from the water level switch and blowing some air through it. If the hose is clear then the water level switch has gone bad. Unfortunately this part has been discontinued by the manufacturer. Here are the breakdown diagrams and Replacement parts for MAYTAG LAT8804AAE WASHER-TOP LOADING | AppliancePartsPros.comGene.
