MJC
#1 Posted : Monday, February 14, 2011 7:40:22 AM(UTC)
MJC
I have a portable Maytag dishwasher that worked fine until one day I decided to use the light wash cycle. It seems like ever since then, it won't let me choose a different cycle. Otherwise it works fine. How can I fix this?
#2 Posted : Tuesday, February 15, 2011 3:26:04 AM(UTC)
A model number may help others help you.
Could be the key is stuck closed.
Also may be a control board problem.
MJC
#3 Posted : Wednesday, February 16, 2011 9:03:43 AM(UTC)
MJC
Don't know what you mean when you say the key could be stuck closed.
#4 Posted : Wednesday, February 16, 2011 11:46:25 AM(UTC)
The key on the keypad when not pressed should be infinite ohms (open)
When you press is it should close, 0 ohms.
So if it always closed the unit thinks it should do a light wash all the time.
MJC
#5 Posted : Wednesday, February 16, 2011 12:53:09 PM(UTC)
MJC
Okay, thanks! I'll see if my husband can fix it with your kind information :)
