silver eagle
#1 Posted : Monday, September 22, 2008 5:21:01 AM(UTC)
silver eagle
I have an Amana frig about 12 yrs old; water to dispenser ok; ice maker makes ice; but the water continues to drip from file pipe, then freezes into glacier.:confused:
libertyappl
#2 Posted : Monday, September 22, 2008 9:03:24 AM(UTC)
libertyappl
Your water valve is probably not shutting off all the way, replace your valve and you should be ok
Nat
silver eagle
#3 Posted : Monday, September 22, 2008 1:23:18 PM(UTC)
silver eagle
I have completely taken out ice maker. Can I test the water valve this way, or did I have to have ice maker installed?:confused:
libertyappl
#4 Posted : Monday, September 22, 2008 1:28:58 PM(UTC)
libertyappl
The easiest way to test the valve is remove the supply line which runs up the back of the unit, place the end of the tub in a cup and see if it gets water in it.
Nat
