tafireman
#1 Posted : Friday, September 19, 2008 6:39:11 AM(UTC)
tafireman
jenn air gas electric range w/ convecton oven
I changed the bake element on the oven and now get an FF on the display. and the fan is running all the time. Is it possiable it is the temperature sensor in the oven and were is the sensor if possiable.
libertyappl
#2 Posted : Friday, September 19, 2008 7:32:20 AM(UTC)
libertyappl
This is the breadown of your unit, Model SVD48600B, I don't see anything showing a FF code...could it be PF?
If so push cancel to see if it goes off.
Nat
ApplianceJunk
#3 Posted : Friday, September 19, 2008 3:26:54 PM(UTC)
ApplianceJunk
FF=Invalid temp reading on power relay board (PRB)
Check/Repair
Check oven temperature sensor and wire harness, or replace power relay board.
Error Code FF on GE Monogram ZISW42EMB (Refrigerator & Freezer Repair)
by jaffman 7/25/2012 10:31:22 AM(UTC)
Jenn-Air Range Error code FF (Oven Repair (including Ranges and Cooktops))
by TonyW 4/4/2009 10:27:02 AM(UTC)
