TonyW
#1 Posted : Saturday, April 4, 2009 10:27:02 AM(UTC)
TonyW
We started the clean cycle two nights ago and durring the night it started beeping and would not stop.
It woke the teenager up and he could not get it to stop beeping so he turned of the cuircit beaker. In the morning I turned it back on and the fan for cooling the top runs full time and will not stop. the burners work but if we try to use the oven we get a FF code about 2-5 seconds after trying to start the oven.
Help! I have looked around the net but have not found a error code FF for Jenn-Air Money is extremly tight so I am trying to fix it myself rather than do without a oven.:(
#2 Posted : Saturday, April 4, 2009 11:59:11 AM(UTC)
Replacement parts for JENN-AIR SVE47600B | AppliancePartsPros.com
Here is a service manual, should be close to yours
http://www.servicematters.com/m...ibrary/docs/16010191.pdf
FF looks like a temp sensor problem. I think PRB stands for Power Relay Board.
Below is info on checking the temperature sensor
http://www.applianceaid.com/oven_temp_sensors_help.html
