bondikovacs
#1 Posted : Friday, September 19, 2008 11:10:43 AM(UTC)
bondikovacs
I plugged washer into generator during hurricane Ike and now it will not run. At first it quit on the Rinse Cycle. Now I plugged it into house power and it will no longer run. What happened and what do I need to buy to fix it?
libertyappl
#2 Posted : Friday, September 19, 2008 11:20:14 AM(UTC)
libertyappl
Does the washer fill or anything?
Nat
bondikovacs
#3 Posted : Friday, September 19, 2008 12:02:27 PM(UTC)
bondikovacs
No, there is no "fill action" at all. After the Rinse Cycle failed and I re set it to fill to wash, the pump struggled for about 5 seconds and then you would hear the water. After a couple of days of this, the water filling process did not sound normal. From there it simply quit everything.
libertyappl
#4 Posted : Friday, September 19, 2008 12:23:18 PM(UTC)
libertyappl
Sounds like the generator was putting out too many amps and burned something up.
Nat
