bigguy
#1 Posted : Thursday, November 15, 2007 7:18:45 AM(UTC)
bigguy
Recently used self-clean option on top oven and after cycle was complete I cannot get heat from either element. Controls, fan and bottom oven work fine. The elements do not appear to be damaged. Based on another thread (posted on 11/1 by choldca and responded to by Gene), it appears that I will need to pull out the oven and replace a thermal fuse/thermal cut off.
Would it be possible to get instruction and part information to replace? Whirlpool Model Series #RBD305.
Please note that I already replaced the microcomputer as well because there was damage to it.
lavonna
#2 Posted : Thursday, September 18, 2008 5:02:12 AM(UTC)
lavonna
I have the exact model and same problem after running self-cleaning mode. Neither bake nor broil elements will begin to heat. Would you please share any response or how you resolved your issue if you have? Thank you!
libertyappl
#3 Posted : Thursday, September 18, 2008 5:32:56 AM(UTC)
libertyappl
Can you both post the entire model numbers off the oven themselves, so to make sure it's the same part you need. There are about 20+ RBD305 models.
Nat
lavonna
#4 Posted : Thursday, September 18, 2008 6:45:52 AM(UTC)
lavonna
My model is rbs305pdb16, I think that just means mine is a single not double oven but I know that would affect the parts. I have the same problem after self-cleaning - neither bake nor broil work but the panel works fine and the fan runs, appears to be heating but there's no heat at all.
libertyappl
#5 Posted : Thursday, September 18, 2008 7:39:00 AM(UTC)
libertyappl
lavonna,
The thermostat/TOD for your oven is part # 4451442 or AP# AP3885687
Nat
lavonna
#6 Posted : Thursday, September 18, 2008 7:53:08 AM(UTC)
lavonna
Awesome, thank you so much! I tried to find a thermal fuse but could only find the thermostat on my model but I wasn't even sure if that would solve the problem. Thank you again!
libertyappl
#7 Posted : Thursday, September 18, 2008 8:03:06 AM(UTC)
libertyappl
Let us know if we can help with anything else.
Nat
